2025-06-06 23:53:39
2.7k
192
Retro Can Cooler!
@coolcreations_4947638
Need a way to chill your beverage?
A single can cooler with a retro twist! This 3D printed travel cooler will make the best model you've ever made!
How to Print
The Body, Insulation, and Handle detail can be printed without support.
The Handle needs to be printed upside down with supports.
Assembly
The Insulation slides into the Body and is pressure fit together, use super glue if needed.
The Handle detail fits into the indent on top of the handle. It will need to be super glued in. You can use a binder clip through the hole in the handle to keep the parts together while gluing.
Once the glue dries you can move onto the next step.
Slide the Handle assembly over the Body assembly. The left and right points of the handle will slide over the embossment on the sides of the body. They should automatically press into place when they are positioned right.
Hope you find this print to be useful!
Let me know if you have any questions or suggestions!
can
retro
cooler
drinks
