2026-10-28 02:46:38
Ribbed Stackable Storage Bins | Support-Free Organizer
@TheGulzar3D_2711681
💎 To get the full library of 3D models with commercial use and Custom Orders, join our Patreon here: https://www.patreon.com/thegulzar3d
🗃️ Ribbed Stackable Storage Bins | Modular Workshop & Desk Organization
Open-front pick bins. Industrial ribbed texture. 100% Support-Free.
Take control of your workspace clutter with these Ribbed Stackable Storage Bins. Designed with an angled hopper-style opening, these bins allow you to grab screws, cables, stationery, and small components instantly—even when stacked several units high!
The exterior features our signature fine vertical fluting, which not only provides a modern industrial aesthetic but also naturally conceals 3D printing layer lines. Precision-engineered stacking lips at the top and base ensure the bins lock securely into place without sliding or tipping, making them the ultimate storage solution for your desk, electronics workbench, craft room, or garage.
📦 What Fits Inside? (120 × 160 × 96 mm Capacity)
With a generous ~1.4-liter internal volume and wide front hopper access, this bin is sized to store:
  • 🔩 Hardware & Workshop: Full boxes of screws, nuts, bolts, washers, heat-set inserts, drill bits, and tape measures.
  • ⚡ Electronics & Tech: Power banks, USB flash drives, charging adapters, coiled cables, and microcontrollers.
  • ✏️ Desk & Office: Full stacks of sticky notes, rolls of packing tape, staplers, dry-erase markers, and stationery packs.
  • 🎨 Crafts & Hobbies: Bottles of miniature paint, glue bottles, sewing threads, clay tools, and card decks.
✨ Key Design Features
  • 🚫 100% Support-Free FDM Printing: Smart self-supporting angles mean you get clean overhangs and smooth surfaces straight off the build plate without wasting filament on supports.
  • 🪜 Stable Interlocking Stacking: Built-in alignment rims keep multi-tier towers rigid and securely nested.
  • 👐 Open-Front Hopper Mouth: Low-profile front scoop lets you reach inside and grab small parts without unstacking bins.
  • 🏛️ Layer-Hiding Ribbed Walls: Vertical fluted texture diffuses light, completely hiding layer seams and giving prints an injection-molded look.
📐 Dimensions & Specifications
  • Overall Footprint: 120 mm (W) × 160 mm (L) × 96 mm (H)
  • Print Style: Monolithic single-piece solid print (no assembly, no glue needed).
  • Modular Fit: Designed to stack vertically in infinite towers.
  • Bed Compatibility: Fits easily on any standard 3D printer build plate (180 × 180 mm and above).
⚙️ Printing Settings
  • Support: None Required.
  • Design Note: The angled front scoop and stacking rims are engineered with self-supporting draft angles.
  • Orientation: Print flat on its bottom face.
  • Layer Height: 0.20 mm or 0.28 mm (The vertical ribbed texture hides layer lines so effectively that printing at 0.28 mm produces fast, flawless results).
  • Wall Loops: 3 to 4 loops (Ensures rigid walls that withstand heavy hardware weight when stacked).
  • Infill: 10% - 15% (Gyroid).
  • Material: PLA, Matte PLA, or PETG (PETG is recommended for heavy-duty workshop/garage environments; Matte PLA in Navy, Forest Green, or Slate Grey looks stunning on modern desks).
stackable bin
storage bin
parts bin
ribbed bin
desk organizer
modular storage
hardware storage
screw organizer
tool box
workshop organizer
office storage
container
support free
no support
anycubic
creality cfs
kobra 3
sparkx i7
gridfinity
stl
