2026-08-23 21:53:56
433
23
Rotate Bolt Latch Lock
@PlaDreams_4057917
Heavy duty Rotate Bolt Latch Lock with hidden screws.
Fits 3.5x20mm screws
Easy assembly.
Only the latch base requires supports but if you turn it sideways it wont need, but you might sacrifice quality.
On the second plate are optional spacers you can use to adjust the height
Using PETG, the assembly is tight so it doesn't need glue. Might differ if using other materials.
lock
latch
boltaction
latchbolt
doorlock
