2026-01-02 13:32:08
1.3k
33
S1 Max Poop Deflector 废料挡板
English: I designed this poop/waste deflector for my new S1 Max. For the best performance, please ensure the screw head on the backplate sits inside the pocket on the model. Please see the picture below. There are 2 ways to attach it to the printer:
  • Insert four 6x3 magnets into the holes: the magnets should stay there snugly. If not, apply a little dab of super glue.
  • Use double-sided tape: nano tape is recommended; foam tape should work as well.
中文:这是一款为S1 Max设计的废料挡板。为了最佳的效果,请确保背板上的凸出的螺丝头嵌入至模型的凹槽内。可以参考最下面的图片。把挡板安装至打印机推荐两种方式:
  • 将4颗6x3圆磁铁推入凹槽:磁铁实测不会掉出来。如果不行的话,可以上些速干胶。
  • 使用双面胶:推荐纳米胶,泡沫胶也行。
S1 Max
S1Max
Poop Deflector
Poop
Waste
废料
废料挡板
