2026-06-02 16:07:32
6.2k
451
SC 140 - 3D Printed RC Airplane (1400mm Wingspan / Custom FPV Cargo Plane)
@spike141_5400898
## Overview
The SC 140 is an upgraded, fully custom-engineered, 3D-printable RC airplane featuring an extended 1400mm wingspan. Designed for long-range flight, FPV setups, and stable aerodynamic performance, this aircraft combines a modular construction with optimized internal space for heavy electronics and payloads.
Whether you are looking for a highly efficient FPV platform, a stable trainer, or a functional cargo and utility RC model, the SC 140 delivers excellent gliding performance, high lift, and a rewarding assembly experience.
## Technical Specifications
* **Wingspan:** 1400mm
* **Length:** 800mm
* **Motor:** Single motor setup
* **Servos:** 4x Micro servos
## Hardware & Reinforcement Rods
Below is the required hardware list for reinforcement and assembly. You can use standard carbon fiber rods, or alternative budget-friendly items as specified:
* **Main Wing Rod:** 6mm x 1000mm (1x)
* **Secondary Wing Rod:** 6mm x 300mm (1x) - Carbon Rod (or BBQ skewer stick)
* **Elevator Trim Rod:** 3mm x 160mm (2x) - Carbon Rod (or BBQ skewer stick)
* **Aileron Trim Rod:** 3mm x 300mm (2x) - Carbon Rod (or BBQ skewer stick)
* **Main Connections:** 3mm x 30mm (4x) - Carbon Rod (or BBQ skewer stick)
* **Alignment Connections:** 2mm x 20mm (16x) - 3D Printing Filament (or toothpick)
## Features & Design Specs
* **Modular Fuselage:** Divided into functional interlocking sections (Front Fuselage, Rear Fuselage, Mid Wings) designed to fit standard 3D printer build plates.
* **Removable Canopies:** Features quick-access Front and Rear Canopy hatches with secure locking tabs for rapid battery swaps and effortless electronics maintenance.
* **Aerodynamic Efficiency:** Precision wing profiles with integrated control surfaces (Ailerons, Elevator, and Rudder) and built-in trim tabs for stable tracking.
* **Generous Electronics Bay:** Ample internal volume tailored to accommodate advanced flight controllers, GPS modules, high-power digital FPV air units, and large LiPo/Li-Ion battery configurations.
* **Pre-Configured File:** A ready-to-print .3mf file is included with all the recommended settings (3-4% Cubic infill, 0.28mm layer height) already configured for your convenience.
🔄 Latest Updates:
  • Update v2 (June 24, 2026):
  • Rear Elevator Servo Bay: Enlarged for a better servo fit.
  • Motor Mount: Changed/redesigned for a better fit.
RC Airplane
FPV Plane
3D Printed Plane
RC Model
Fixed Wing
UAV
Aeroplane
SC140
