2026-07-16 23:55:43
643
10
Sci-Fi Book Nook - The Expanse
@Kopp3D_1668879
If you have a bookshelf full of sci-fi, this is the perfect nook for you. Inspired by The Expanse, you can see a space marine in power armor (I like to think it's Bobbie) standing on a desolate rock, looking up at a spaceship (Rocinante) entering the ring gate (though you can pretend its a black hole if you're not familiar with the Expanse), while a space station (Medina) looms above. Place an LED puck inside the planet on the top insert to make the whole interior glow any color you like - red for Mars or blue for the protomolecule - the possibilities are endless. Any 20mm by 30mm RGB LED Tea Light will work (I got mine from Amazon).
Created using a mix of Blender, Onshape, and Makerlab, everything slides together - no glue and no AMS required (one color change only). Comes with two different bases, one flush with the box and one with an extender. Up to you which one you want to use depending on your decoration style.
The following image is the assembly instructions:
the expanse
book nook
scifi
science fiction
planets
space
moon
mars
the ring gate
nauvoo
behemoth
medina station
rocinante
led
spaceman
astronaut
stars
