2026-07-06 07:48:19
3k
265
Scraper Stay-Sharp
@FlameForge_3783139
Tired of printing entire scrapers just to throw them away when the edge gets dull? The Stay Sharp Scraper is the ultimate waste-free solution for your 3D printer maintenance.
🚨 NEW UPDATE: Now includes the Mini Version! A more compact, ergonomic handle that prints in just 53 minutes! Save time and filament without losing scraping power.
🌟 Key Features:
  • Truly Waste-Free: When the blade wears out, just print a new 5-gram replacement. Keep your handle forever!
  • Heavy-Duty Design: Unlike fragile clamshell designs with tiny pins, this blade slides directly into a solid pocket, transferring all scraping force to the robust main body.
  • Zero Glue Required: Fully 3D printed mechanical assembly.
  • Ergonomic Lobed Nut: Tighten the blade securely using just your fingers—no extra tools or metal hardware needed.
⚙️ Recommended Print Settings:
  • Material: PLA for the Handle (for speed) / PLA or PETG for the Blade (PLA keeps a sharper edge, PETG is more durable).
  • Layer Height: 0.15 mm (only for the blade and nut), put any other layer hight for que main body (recomended 0.2mm).
  • Strength: Print the Blade 10% solid (2 or 3 perimeters) for an efecient resistence.
  • Pro-Tip: Print the top surface of the blade slowly (e.g., 50/80 mm/s) so it comes out glossy and is easy to clean from glue residue!
🔧 Assembly: Simply slide the blade into the front slot of the handle, screw the lobed nut into the thread, and tighten it with your fingers. You're ready to scrape!
scraper
bed scraper
tool
3D printer tool
interchangeable
replaceable
anycubic
maintenance
utility
waste free
