2026-07-05 22:44:54
1.3k
104
Scrat the Squirrel (Ice Age)
@dharian_5531540
The eternal chase for the elusive acorn continues!
This is a highly expressive, 3D-printable figurine of Scrat, the chaotic and beloved saber-toothed squirrel from the Ice Age franchise. Capturing his signature frantic energy, wide-eyed obsession, and desperate grip, this model is a fantastic piece of movie nostalgia for any fan of the films.
This version has been specifically engineered for single-color printing. You don’t need an AMS or complex multi-material setup to make him look great. The model relies on deep fur textures, prominent facial features, and sharp panel lines to create natural shadows that pop beautifully using just a single spool of filament. It has been tolerance-tested on Anycubic FDM printers (such as the Kobra, Vyper, or Mega series) to ensure clean handling of his thin limbs and tail.
⚠️ IMPORTANT DISPLAY NOTE: True to his clumsy and frantic nature in the movies, this figurine cannot stand by itself! Because of his dynamic, off-balance pose and heavy tail, you will need to prop him up, glue him to a custom base, or use double-sided tape/mounting putty under his feet to keep him upright on your desk or shelf.
Model Features
  • Anycubic Slicer Calibrated: Geometrically optimized to handle the retraction transitions between his skinny legs, bulging eyes, and massive tail without causing excessive stringing.
  • Highly Detailed Sculpt: Captures every bit of Scrat's desperate personality, from his twitchy snout to his signature prehistoric teeth.
Recommended Print Settings
  • Layer Height: 0.12mm to 0.16mm is highly recommended to cleanly capture his bulging eyes, whiskers, and the textured details of his fur.
  • Infill: 10% - 15% (Gyroid or Grid. Keep it on the lower side to reduce the weight of his large tail).
  • Supports: Yes, supports are absolutely necessary for his long snout, outstretched arms, and heavy tail. Tree/Organic supports configured in your preferred slicer (Anycubic Next, Cura, or PrusaSlicer) are highly recommended for clean, painless removal.
  • Brim: A 5mm to 8mm outer brim is highly recommended to keep his small feet firmly anchored to your Anycubic print bed during the print process.
IceAge
Scrat
Squirrel
Acorn
Animation
Movie
Character
Figurine
Figure
DeskToy
Model
3DPrint
FanArt
Cute
Funny
Collectible
