2026-09-22 01:28:45
395
16
Servilletero con Tapa Abatible | Hinged Napkin Holder with Lid
@DrCar_4680089
A practical and clean-looking napkin holder designed to keep napkins protected, organized and always within easy reach.
The box has a compact square design with a hinged lid that opens wide for easy refilling. The front finger cutout makes it simple to lift the lid, while the enclosed design helps keep napkins away from dust, splashes and everyday mess.
It works especially well in kitchens, dining tables, workshops, offices, caravans or anywhere you want a simple and tidy way to store napkins.
The design was created with 3D printing in mind, keeping the geometry simple and functional while still giving the finished piece a modern appearance.
External dimensions:
175 mm wide
175 mm deep
65 mm body height
The lid adds only a small amount to the total height.
The design is ideal for standard folded napkins and gives you plenty of room without making the box unnecessarily bulky.
You can print the body and lid in matching colors for a minimalist look, or use contrasting colors to make the hinge and lid stand out.
The version shown in the photos was printed in black and purple.
No complicated assembly is required. Once printed, the result is a solid, reusable napkin box that looks much cleaner than keeping napkins loose on the table.
If you print one, I would love to see your color combination and setup. Upload your make and show how you are using it!
Descripción en español
Un servilletero práctico y limpio, diseñado para mantener las servilletas protegidas, ordenadas y siempre a mano.
La caja tiene un formato cuadrado compacto y una tapa abatible que se abre ampliamente para poder rellenarla con facilidad. El rebaje frontal permite levantar la tapa cómodamente, mientras que el diseño cerrado ayuda a proteger las servilletas del polvo, salpicaduras y suciedad del día a día.
Va muy bien para cocina, mesa de comedor, taller, oficina, caravana o cualquier sitio donde quieras tener las servilletas recogidas de una forma más limpia y ordenada.
El diseño está pensado desde el principio para impresión 3D, con geometrías sencillas, funcionales y fáciles de imprimir, pero intentando mantener un aspecto moderno una vez terminado.
Medidas exteriores:
175 mm de ancho
175 mm de fondo
65 mm de alto del cuerpo
La tapa añade muy poca altura adicional.
Tiene capacidad suficiente para servilletas plegadas estándar sin convertir el servilletero en una caja excesivamente grande.
Puedes imprimir cuerpo y tapa en el mismo color si buscas algo discreto, o usar colores diferentes para darle más personalidad. En las fotos se puede ver una combinación en negro y morado.
No necesita un montaje complicado. Una vez impreso tienes un servilletero sólido, reutilizable y mucho más ordenado que dejar las servilletas sueltas sobre la mesa.
Si lo imprimes, me encantará ver tu combinación de colores y cómo lo estás usando. Sube tu make y enséñanos el resultado.
napkin holder
napkin box
kitchen organizer
kitchen storage
hinged box
storage box
kitchen accessory
servilletero
caja servilletas
organizador cocina
