If the “pen is mightier than the sword”… why not have both for insurance? This simple mod to the classic Fine Point Sharpie adds a new aesthetic sure to please your medieval enthusiasts.
This does not replace the existing Sharpie cap but slides over like a cover. Sharpie has a very well-designed internal o-ring/seal to keep markers fresh and secured. Why redo their hard work?
Have a unique colored sharpie? Color part of the hilt with it!
To install
- Use your clippers to remove the pocket clip and small nub lower down. If the cut is not clean, a good sanding will help.
- Ensure the printed hilt slides over the pen cap; this should be a snug slip fit.
- (Optional) sanding the cap prior to gluing with help the hilt stick.
- Add your glue of choice to the inside of the hilt and press-on to the Sharpie cap.
Printing Notes
- Nozzle: 0.4 or smaller
- Build Plate Adhesion: Brim or Raft is recommended due to the small contact area
- Supports: Touching Build Plate; supports only require for the cross guard
- Orientation: Printing standing straight should yield the best results
Show us your makes; we'd love to see them!
https://www.printables.com/model/252108
