Shelf Bracket Topology Optimized - Smaller version
This is a lightweight, topology-optimized shelf bracket designed for strength and minimal material usage. Its organic structure ensures high load capacity while maintaining an elegant appearance.
Dimensions: 125 mm wall side × 125 mm shelf side
Mounting holes: 4 mm diameter, suitable for standard 4 mm screws
Support-efficient design: Optimized for 3D printing with minimal supports
Installation: Designed for mounting to both wall and shelf
Recommended print settings:
Material: PETG or PLA
Layer height: 0.2 mm
Perimeters: 3 or more (depending on load)
Infill: 20-30% (gyroid or cubic recommended)
Supports: Enable tree supports for optimal results
Perfect for modern or industrial interiors where strength and design go hand in hand.
