2025-12-31 02:33:11
1.3k
42
Shop Vac Replacement Hose Couplers
@TomS_1708581
I have a 50 year old Sears Craftsman wet/dry shop vacuum. The vacuum itself works fine and has served well for all these years. Unfortunately some of the hard plastic connections and various attachments have fatigued from age and use. This print model to create replacement parts for the 2 inch flex hose.
There is a plug which is inserted into the flexible tube end. This plug mates to a coupler and then to another plug in another hose. You will need two plugs and a coupler to attached two hoses. Note that the plug is difficult to fully insert into a hose. This is to ensure it does not dislodge itself. Use electrical tape to provide an air tight fit.
Shop
Vacuum
Shop Vac
