A determined skeleton makes its way across a striking rock formation. With its dynamic pose, multiple rock levels, and detailed design, the model makes an eye-catching decoration for a shelf, desk, or display cabinet.
It is especially suitable for fans of skeletons, climbing, gothic designs, fantasy, and of course Halloween.
I intentionally oriented the model on the build plate so that the required support structures are located exclusively on the back side. This keeps the visible front surfaces as clean as possible and prevents support marks from affecting the overall appearance. Please remove the supports carefully, especially around the finer details of the skeleton. It takes a little patience, but the final result is definitely worth it.
The model is 13 cm tall at its original size, but it can be scaled up or down freely depending on your preferred size or available build volume. Please note that very small scales may reduce some of the finer skeleton details.
