2026-10-13 20:30:14
3.4k
585
Skull Within a Skull – Halloween Horror Prop
@drakeforge3d_5567152
A skull hiding another skull within — a disturbing Halloween prop with a striking double-skull design. The fractured forehead reveals a smaller skull emerging from inside, framed by jagged bone fragments and spreading cracks. Deep eye sockets, sculpted teeth and a weathered surface complete its eerie appearance.
Perfect for Halloween displays, haunted house scenes, gothic shelves or horror-themed tabletop arrangements. Display it in a single colour or paint it with aged bone tones and dark washes to emphasise the cracks and the skull within.
Designed for FDM 3D printing. Supports are required. Remove them carefully around the fractured forehead, inner skull and facial cavities to preserve the sculpted details.
Guide
1. DRY THE FILAMENT
  • Recommendations:
Skull
Skulls
Halloween
Halloween decor
Halloween Skull
Prop
Horror
creepy
spooky
monster
art
decor
