2026-10-08 17:21:24
267
10
Skull candle holder - NO AMS
@Arjenbulkens_4079570
Skull Candle Holder 💀
A seated skeleton holding a tray for an LED candle, with a detailed skull, hooded robe and two smaller skulls at the base.
The skeleton and tray are supplied as separate parts on two print plates, so you can print them in different colours without an AMS. Attach the tray after printing.
Dimensions assembled: approximately 181 × 178 × 220 mm.
Tray inner diameter: approximately 100 mm.
Print profile:
• 0.24 mm layer height
• 3 walls
• 8% gyroid infill
• Tree supports enabled for the skeleton
Remove supports carefully around the fingers, arms and chin. Small support marks may remain.
For flameless LED candles only. Do not use real candles.
halloween
candle holder
LED candle holder
horror
skull
seperate
NO AMS
spooky
