2026-10-12 17:32:50
226
Skull of the Abyss Orc - Gothic Halloween Display
@drakeforge3d_5567152
Bring a touch of dark fantasy to your collection with this imposing Demon Skull. Thick, curled horns frame a cracked cranium, while deep eye sockets, prominent fangs, and a heavy jaw create a fierce, menacing expression. Sculpted bone textures and ridged horns give the model plenty of character from every angle.
A striking display piece for Halloween decorations, gothic shelves, fantasy gaming spaces, or horror collections. Display it in a single filament color, or paint it to highlight the cracks, horns, and skeletal details.
Printing information
  • Designed for FDM 3D printing.
  • Supports are required.
  • Remove supports carefully around the fangs, horn tips, and jaw.
  • A finer layer height can help showcase the sculpted surface details.
   Guide
1. DRY THE FILAMENT
  • Recommendations:
skull
skulls
orc skull
gothic
halloween
halloween prop
display
monster
monster skull
art
decor
prop
halloween decor
dark fantasy
