2026-10-12 17:29:16
219
Skull of the Succubus - Dark Fantasy Display
@drakeforge3d_5567152
Add an elegant touch of horror to your collection with this Succubus Demon Skull. Sweeping, ridged horns frame an ornate skull with sharp bone contours, deep eye sockets, and a snarling jaw filled with pointed fangs. Its elaborate brow and sculpted cheekbones combine gothic elegance with a fierce demonic appearance.
A striking decoration for Halloween displays, gothic interiors, dark fantasy collections, or tabletop gaming spaces. Display it in a single filament color, or paint it to bring out the intricate bone shapes and horn textures.
Printing information
  • Designed for FDM 3D printing.
  • Supports are required.
  • Remove supports carefully around the teeth, horn tips, and pointed bone details.
  • A finer layer height can help capture the sculpted textures.
   Guide
1. DRY THE FILAMENT
  • Recommendations:
skull
skulls
succubus
dark fantasy
display
fantasy prop
prop
fantasy
horror
spooky
creepy
art
decor
demon
