Universal Baby & Pet Gate Wall Spacer / Adapter
Have you ever tried to install a safety gate only to find out that your thick skirting board (baseboard), handrail, or uneven wall makes it impossible? This functional 3D-printed wall adapter solves that exact problem!
It creates a perfectly flat, secure surface to mount or press your safety gate extensions against, preventing any slips and protecting your walls.
🛠️ Features & Design
- Problem Solver: Ideal for bypassing thick baseboards, lower wall moldings, or upper banisters/handrails.
- Rock-Solid Stability: Provides a wide, flat surface so pressure-mounted gates won't slide or wobble.
- Easy Installation: Includes countersunk screw holes if you prefer a permanent hardware mount, but also works perfectly with heavy-duty double-sided tape.
🖨️ Recommended Print Settings
- Material: PETG or ABS/ASA (Highly recommended for mechanical strength and child/pet safety). PLA can work but might creep under high continuous pressure.
- Wall Loops / Perimeters: 4 or 5 (Crucial for structural strength against gate pressure).
- Infill: 25% - 40% (Grid, Gyroid, or Honeycomb for maximum compression resistance).
- Supports: No supports needed if printed flat on the bed.
Adaptador / Separador de Pared Universal para Barreras de Seguridad
¿Has intentado instalar una puerta para bebés o mascotas y te has encontrado con que el rodapié (zócalo), el pasamanos o una pared irregular te lo impiden? Este diseño soluciona ese problema de raíz.
Crea una superficie completamente plana y segura para apoyar o atornillar los extremos de la barrera, evitando que se deslice y protegiendo la estructura de tu casa.
🛠️ Características del Diseño
- Solución práctica: Ideal para salvar la diferencia de grosor del rodapié abajo o esquivar barandillas arriba.
- Máxima estabilidad: Ofrece una base amplia para que las barreras a presión no se muevan ni cedan.
- Montaje flexible: Cuenta con agujeros avellanados para fijarlo con tornillos, aunque también se puede usar con cinta de doble cara de alta resistencia.
🖨️ Parámetros de Impresión Recomendados
- Material: PETG o ABS (Muy recomendados por su resistencia mecánica). Si usas PLA, asegúrate de meter bastantes paredes.
- Paredes (Wall Loops): 4 o 5 (Es lo más importante para que soporte la fuerza de la barrera sin romperse).
- Relleno (Infill): 25% a 40% (Giroide o Rejilla).
- Soportes: No los necesita si se coloca plano sobre la cama de impresión.
