2026-10-21 01:42:06
41
Space Marine Ultramarine Intercessor – High-Detail Miniature & Display Statue
@jujinya_2995263
Bring the defender of humanity to your tabletop or display shelf! This high-detail 3D printable model features a classic Ultramarine Space Marine equipped with a standard Bolt Rifle, standing atop a textured battle-ruin base. Designed with crisp panel lines, iconic iconography (shoulder insignia, Ultramarines crest and tactical markings) and optimized geometry for clean slicing, it is ideal for both small-scale tabletop miniatures and large display statues.
FEATURES
- Iconic Ultramarine Design: Faithful details including the shoulder markings, knee pad symbols, helmet grill and backpack power unit.
- Integrated Scenic Base: Ruined concrete slabs, debris and ground texture for immediate display right off the print bed.
- Scalable Geometry: Works great scaled down to 28mm/32mm for tabletop gaming (resin recommended) or scaled up to 150mm+ as a desktop display piece (FDM compatible).
RECOMMENDED PRINT SETTINGS (FDM, PLA/PETG)
- Layer Height: 0.12mm - 0.16mm for smooth surfaces and fine horizontal details.
- Infill: 15% - 20% (Gyroid or Grid).
- Supports: Required (Tree / Organic supports recommended under arms, weapon barrel and shoulder pads).
- Brim: Recommended for base stability if printing scaled up.
RESIN (SLA) PRINTING - BEST DETAIL
- Layer Height: 0.03mm - 0.05mm.
- Orientation: Tilt backward 30° to 45° to avoid flat layer suction on shoulder pads and base.
- Drain Holes: Add drain holes at the bottom of the base if printing hollow.
POST-PROCESSING & PAINTING TIPS
- FDM: A quick coat of high-build primer helps smooth out layer lines before painting.
- Colors: Traditional Ultramarine blue armor, gold/bronze shoulder trim, matte black or metallic Bolt Rifle, and warm brown/grey base tones.
Disclaimer: This is a fan-art model created for personal, non-commercial use and display purposes.
If you like this model, please leave a rating, like, and share your makes! Happy printing!
warhammer 40k
space marine
ultramarines
intercessor
40k
miniature
tabletop gaming
grimdark
sci-fi statue
warhammer
adeptus astartes
bolter
display model
cosplay props
sci-fi miniature
painter model
fan art
pla
resin print
3d printable
