2025-10-07 12:08:32
4.6k
89
SpaceX Super Heavy Exploratory Edition 超重助推探索版
English: This is an exploratory model of the latest SpaceX Super Heavy with interior details, only available on Makeronline. I mostly referenced the new Booster 13 (B13). The model + base is about 325 mm tall or ~12.8 in. The assembly is very straightforward, but an assembly instructor is provided below. Depending on printer models, you may need to apply glue during assembly. It is fully compatible with my OLM model, Starship V2 model, and HLS model.
中文:这是一款基于最新SpaceX超重助推 13 (B13) 的探索版模型,具有一些内构,是Makeronline独占。算上底座,模型总高度为325 mm。组装较为简单,具体可以参照下方的组装指南。取决于您的打印机型号,组装的时候可能会需要用到胶水。它可以完美兼容我的OLM模型、二代星舰模型、以及星舰HLS模型。
English: I uploaded 4 print profiles:
  1. ACE Pro Needed: Needs an ACE Pro to give the letters on the nameplate a different color than the base.
  2. No ACE Pro Needed: No ACE Pro needed. The letters on the name plate will have the same color as the base.
  3. Optional Fin: 0.2 Nozzle: print the fins using a 0.2 mm nozzle to give them more details. This is completely optional, as the above print profiles already include fins.
  4. Hot Staging: V2 hot staging ring based on SpaceX's slides. Print it if you would like to stake my Starship models on top of the Super Heavy.
中文:我上传了4个打印配置:
  1. ACE Pro Needed:需要用到ACE Pro。主要为了给底座上的铭牌上色。
  2. No ACE Pro Needed:无需用到ACE Pro。铭牌字体和底座为同一个颜色。
  3. Optional Fin: 0.2 Nozzle:使用0.2喷头打印的栅格舵,细节会更好。请按需打印。前两个打印配置已经包含栅格舵了。
  4. Hot Staging: 基于SpaceX ppt上的二代热分离环。想要把我的星舰模型叠在超重助推上的话需要打印。
SpaceX
Super Heavy
Starship
超重助推
星舰
