2026-10-27 05:38:13
34
Spiral Ribbed Desktop Bin | Support-Free Desk Organizer
@TheGulzar3D_2711681
💎 To get the full library of 3D models with commercial use and Custom Orders, join our Patreon here: https://www.patreon.com/thegulzar3d
🗑️ Spiral Ribbed Desktop Bin | Kinetic Texture Meets Daily Utility
Dynamic twisting flutes. Generous 1.5L desktop capacity. 100% Support-Free.
Upgrade your workspace with the Spiral Ribbed Desktop Bin. Designed with a sophisticated twisting fluted geometry wrapping around a soft-cornered square profile, this versatile organizer completely conceals FDM 3D printing layer lines while delivering an architectural, designer finish to any desk, studio bench, or bathroom vanity.
At 128 × 128 × 135 mm, this bin is sized to bridge the gap between an oversized stationery cup and a desktop wastebasket. Use it as a dedicated 3D printer purge-line bin, a high-capacity desk tool caddy, or an elegant modern indoor planter/cachepot for succulents and houseplants.
📦 What Fits Inside? (128 × 128 × 135 mm Footprint)
  • 🧵 3D Printer Purge Collector: Holds multiple prints' worth of filament purge lines, brims, and support scraps right next to your printer.
  • ✏️ High-Capacity Stationery: Holds 30+ pens, thick markers, drafting rulers, art brushes, and full-size scissors.
  • 🪴 Indoor Planter / Cachepot: Perfectly conceals standard 3.5" to 4" (90–100 mm) round or square nursery pots.
  • 🪥 Vanity & Bathroom Caddy: Holds hairbrushes, combs, makeup palettes, and grooming essentials.
  • 🔧 Workshop Tool Holder: Great drop bucket for screwdrivers, pliers, calipers, and hex keys.
✨ Key Design Features
  • 🚫 100% Support-Free Printing: Continuous twisting flutes are engineered with natural self-supporting overhang angles—zero supports and zero post-cleanup.
  • 🌀 Layer-Line Hiding Ribs: Dynamic spiral fluting diffuses light reflections across the surface, giving the print an injection-molded, ceramic appearance.
  • 🛡️ Reinforced Top Rim: Thick, rounded collar provides superior structural stiffness and an easy grip when moving or emptying the bin.
  • ⚡ Fast-Print Optimized: Smooth continuous toolpaths make this an exceptionally fast, reliable print even at higher layer heights.
📐 Dimensions & Specifications
  • Overall Size: 128 mm (W) × 128 mm (L) × 135 mm (H)
  • Profile: Rounded soft-square footprint (space-saving desk fit).
  • Print Style: Monolithic single-piece solid print (watertight base, zero assembly).
  • Bed Compatibility: Fits easily on all standard 3D printer build plates (180 × 180 mm and above).
📂 File Types Included
  • Creality Print .3mf: Pre-configured project; optimized for SPARKX i7 and Creality CFS.
  • Anycubic ACE Pro .3mf: Pre-configured project; optimized for Anycubic Kobra 3.
  • Bambu Studio .3mf: Pre-configured project ready to slice.
  • STL: Universal clean, high-resolution mesh file.
⚙️ Printing Settings
  • Support: None Required.
  • Design Note: Sloped spiral flutes and vertical wall drafts print 100% support-free.
  • Orientation: Print flat on its bottom base.
  • Layer Height: 0.20 mm or 0.28 mm (The ribbed texture hides layer lines so effectively that 0.28 mm prints fast with zero visible quality loss).
  • Wall Loops: 3 to 4 loops (Ensures thick, durable walls and a weighted, premium feel).
  • Infill: 10% - 15% (Gyroid).
  • Material: Matte PLA, PETG, or Silk PLA (Matte Navy Blue, Slate Black, Sandstone, or Emerald Green yield striking visual results).
spiral bin
desktop bin
desk organizer
ribbed bin
trash can
pen holder
pencil cup
plant pot
succulent planter
vase
storage box
wastebasket
poop bin
support free
no support
modern decor
anycubic
creality cfs
kobra 3
stl
