2026-09-11 00:38:56
236
Sponge Rack - Upgraded
@JGMaker_4890379
This is an upgraded rack from my previous push-fit assembly version. For connecting the left and right frames, the 4 connecting rods are all the same with left-handed and right-handed screw threads at the ends. This allows for a more secure fit unlike the push-fit version that may disassemble more easily. Two different rod lengths (60mm, 70mm) are provided for either a more compact or wider fit as desired. The frames are also thicker here. This version should be more rigid and long lasting while keeping sponge drip messes away from your kitchen top. Enjoy!
Note: For assembly, position each rod in the respective holes in the left and right frames. Ensure the left-handed thread goes to the left-frame and right-handed thread to the right-frame. Twisting the connecting rod in one direction tightens and bring the left and right frames together. Twisting in the opposite direction loosens. The top-most rod goes in last after position the frames over the neck of the faucet.
Sponge rack
Kitchen sink
Sponge drying
Scouring pad drying
Scouring pad rack
Kitchen faucet
Sponge holder
Scouring pad holder
Screw fit
