This is designed to replace the stock spool holder for Anycubic Kobra S1. The original limits the spool central hole to at least 53 mm, disallowing it to hold spools with central hole diameters of smaller than 50 mm and also the Prusa USS dry box. This adaptation expands the range of usable spool holders (central holes down to 30 mm) and also allows the Prusa USS dry box to go on as well for externally feeding e.g. flexible filaments that need to be kept dry. Works great on my Kobra S1. Note that the Prusa USS dry box has a round and a square side, and one should position the square side away from the Kobra S1 "poop" chute so as not to block it. Hope you enjoy using this.
Printed with PETG using 0.16 mm layers and supports.
