2025-06-02 06:35:20
2.5k
133
Ssangyong Park - Mini Electric Realistic Dragon Boat Race/双龙游园-mini电动拟真龙舟赛
Be sure to read the introduction before printing the model
This is the original part, if you need to print it, please print the second creation part, link
V5.31: V1.1 is updated
This version has not been printed and tested, nor has the configuration files synced, but almost all of the issues have been fixed: the motor torque has been fixed for small stalls, the higher torque straight shaft motor has been replaced, and the motor has been changed to a single motor
Added a cable protection baffle to fix the problem of wire winding gears
Fix button issues
Fixed the issue that it was difficult to put the sliding rheostat and switch board
Fix the details
I've been thinking, is the Dragon Boat Festival just a dragon boat and two zongzi? Why can't we make it a little more flexible?
As a result, it, the most mini dragon boat, was born
Before I made it happen, I set 6 goals for it:
• Realistic and simple and cute
• Dynamic and static beauty
• The first structure of the whole network
• Combination of flat and three-dimensional
• Soft lighting and scenographic décor
• Leave the right of DIY to the user to the greatest extent
It has been reached, but that does not mean that regrets do not exist
Let's take a look at it first:
The double motor drives the gear, so that the dragon boat can speed along the figure 8 track, can put 1, can put 2, like a fierce dragon boat race, rotating the governor, is speeding the dragon boat and seems to be swimming slowly on the lake, leisurely
On the surface of the lake, the fish are jumping, and the lotus flowers in the lotus leaves are slim and vibrant~
What's more, through my first magnetic repulsion suspension structure, zongzi (self-selected and printed) (you can also put other things) are jacked up in turns - you can put salty zongzi and sweet zongzi, what to eat for breakfast today (hehe), you can also engrave your Dragon Boat Festival blessings on the four signs, which one to jack, which wish can be realized~
There are also two cob atmosphere lights, which change with the intensity of the dragon boat race, the more intense the dragon boat race, the brighter the atmosphere lights, secretly tell you a cold knowledge, press the button below, and you can also turn off the lights~ Back to business:
First acknowledgments:
@wuguigui (Mr. Zhang) provided the standard gear website, which helped me a lot
@蒙野骨手的八字运转龙腾四海为我提供的灵感, t
But for the record, the transmission method I used is different from that of Mengye's bone hand, and I only borrowed the appearance of the figure 8 run
You need to:
Hardware list:
1. Y-cable (2 SH1.0 males, 1PH2.0 female)
2. N20 10D straight shaft motor, 120-160 speed, more than 700 torque
3. BT2×8 self-tapping screws
4. M2.5x10 screws
5. 1 copy of 200mm SH1.0 cable (5 pcs)
6. 2 parts of 6x2 magnets, 40 pcs
7. 2 parts of 5x1 magnets, 40 pcs
8. 4 parts of 20x3 magnets, 30pcs
9. 1 distribution board kit
At a minimum, the following effects must be met
a:Switch board or rotary rheostat
b:with electrical appliances
Suggestion: Except for the PH2.0 interface, the rest are SH1.0 interfaces
10. Rotate the potentiometer plate 1 part, 2 pieces
11. COB strip light 300mm, 2pcs
12. SH1.0 to PH2.0 cable, 200mm is recommended, 1 piece
13. ph2.0 to USB-A wiring
14. Jumpers, at least 5 pieces
15. Bring your own 35mm consumables, 40 are recommended
Unspecified electronic components are recommended SH1.0 excuses, otherwise it may be necessary to transfer the interface
The total is about 300 yuan
Consumables Recommendations:
Blue, green, and white are the main colors, and the rest are optional
However, translucent filaments are required as a rigid requirement for COB baffles
Note that this model cannot be printed in K1 and smaller sizes
The center of the top plate is the magnetic ejection suspension area, where the printing direct pin shaft can be used to insert large and small zongzi
The summer ponds on both sides are customized by you, and when you finish printing, it will be barren, and it is up to you to decide whether you want to insert lotus leaves and lotus flowers or fish here!
This model contains all the original components, if you need to print it, please print the second creation kit at the same time as printing this model (upload later)
Assemble:
The print configuration has been added with a pause, put in the magnet at this point:
Put two large wheels into 20x3 large magnets, put 1 magnet in each of the 6 (5 can also be) positions on one side, a total of 12 (10), it is recommended that the magnetic poles are consistent with each position of the dragon boat to put a 5x1 magnet, and it is recommended that the magnetic poles are consistent with the hinge of each card A 6x2 magnet is placed to ensure that it attracts with the dragon boat
The remaining assembly is described, and the GIF assembly is being rendered
It is true that it is exquisite, but it still leaves many regrets
• Double switch board to control double light strips, which is very wasteful
• In order to rush to work (I live on campus in the first year of junior high school, and only have weekend time), coupled with personal modeling ability, dragon boats, zongzi, and lotus all call MW ready-made model two creations
• I haven't thought about what to do on the side until now, what is left blank is space, and what flows away is creativity
• Waste of consumables for large area of support, undivided parts make printing necessary for CFS
• Use a lot of magnets for the levitation effect
It's a huge leap forward in my modeling work, but it's still a huge chasm away from perfection
So, stay tuned, V2 version, the next leap
在打印该模型前,请务必看完简介
此为原创部分,如需打印请再打印二创部分,链接
5.31:V1.1版本更新
这个版本未经打印测试,也未同步配置文件,但已修复几乎所有问题:修复电机扭矩小停转的问题,更换了更大扭矩的直出轴电机,且改为单电机
增加走线保护挡板,修复走线缠绕齿轮问题
修复按钮问题
修复滑动变阻器,开关板放入困难问题
修复细节
我一直在想,端午,就是一条龙舟俩粽子吗?为什么不能让它灵动一点呢?
于是,它,最mini的赛龙舟,横空出世
在让它现世前,我为它定了6个目标:
• 拟真而又简约可爱
• 灵动而又有静态美
• 全网首创的结构
• 平面与立体结合
• 柔和的光效和场景化的装饰
• 最大程度将DIY的权利留给用户
它达到了,但这不等于遗憾并不存在
先来看看它:
双电机带动齿轮,使龙舟沿8字轨道飞驰,可放1条,可放2条,仿若激烈的龙舟竞速,旋转调速器,正在飞驰的龙舟又似缓慢游于湖上,悠闲自在
湖面上,鱼儿正在跃动,接天莲叶中荷花亭亭玉立,生机勃勃~
what's more,通过我首创磁相斥悬浮结构,粽子(自行挑选打印)(你也可以放别的东西)被轮流顶起——你可以放上咸粽子和甜粽子,顶起什么今天早饭吃什么(呵呵),四块牌子上你还可以刻上你的端午祝福,顶起哪块,哪个愿望就能实现~
还有两条cob氛围灯,随龙舟竞赛激烈度而变,龙舟竞赛越激烈,氛围灯越亮,偷偷告诉你一个冷知识,按下下方按钮,还可以实现关灯哦~言归正传:
先鸣谢:
@wuguigui(张老师)提供的标准齿轮网站,这很大的帮助了我
@蒙野骨手的八字运转龙腾四海为我提供的灵感,链接如下:
但特别声明,我采用的传动方式与蒙野骨手的不同,我仅借鉴了8字运转外观
你需要:
五金件清单:
1. Y型线(两个sh1.0公头,一个ph2.0母头)
2. N20 10D直出轴电机1个,120-160转速,700以上扭矩
3. BT2×8自攻螺丝
4. M2.5x10螺丝
5. 200mm sh1.0连接线1份(5条)
6. 6x2磁铁2份,40颗
7. 5x1磁铁2份,40颗
8. 20x3磁铁4份,30颗
9. 分电板套件1份
要求至少能满足以下效果
建议:除了电源为ph2.0接口,其余为sh1.0接口
10. 旋转电位器板1份,2个
11. COB灯带300mm,2条
12. sh1.0转ph2.0连接线,建议200mm,1条
13、ph2.0转USB-A接线
14、跳线,至少5个
15. 自备35mm左右耗材段,建议40根
未注明的电子元件都建议sh1.0借口,否则可能需要转接口
合计约300元
耗材建议:
蓝,绿,白为主色,其余自选
但半透明耗材为硬性需求,用于cob挡板
注意,K1及更小尺寸无法打印该模型
顶板中央为磁顶出悬浮区,这里利用打印直销轴,可以插上大大小小的粽子
两侧的夏日池塘由你定制,打印完时一片荒芜,具体是要在这里插入荷叶荷花还是鱼儿,由你决定!
此模型包含所有原创组建,如需打印请在打印此模型的同时,打印二创配套组件(稍后上传)
组装:
打印配置已添加暂停,此时放入磁铁:
两个大轮放入20x3大磁铁,在一侧6(5个也可以)个位置每个放1枚磁铁,累计12(10)枚,建议磁极一致龙舟每个位置放入一枚5x1磁铁,建议磁极一致铰链每个卡一枚6x2磁铁,保证与龙舟相吸
剩余组装见描述,GIF组装图正在渲染中
的确,它很精致,但它仍留下了许多遗憾
• 双开关板控制双灯带,非常浪费
• 为了赶工(我初一住校,只有周末时间),加上个人建模能力原因,龙舟、粽子、荷花都调用mw现成模型二创
• 我直到现在都没想好侧面做什么纹饰,留白的是空间,流走的是创意
• 大面积的支撑浪费耗材,未分件使打印必须要CFS
• 为磁悬浮效果使用大量磁铁
它是我建模作品的一个巨大的飞跃,但离完美,还隔着巨大的鸿沟
所以,敬请期待,V2版本,下一个飞跃
端午
儿童节
机械
装饰
实用
diy
美观
电机
氛围灯
可动
631.21KB
466.78KB
570.59KB
274.88KB
321.58KB
384.57KB
View All
