2026-09-07 22:47:31
876
50
Star Trek Communicator/ Combadge Props
@Varulfen_5201733
Star Trek Communicator Badges – The Next Generation and Voyager
I created these two communicator badges as custom 3D models based on the appearance of the props used in Star Trek. The set includes the classic version from *Star Trek: The Next Generation* as well as the later variant used in *Star Trek: Voyager* and other series. Mounted just like the original using a Velcro strip that is glued into a recess at the back.
For the TNG communicator, the silver-colored Starfleet delta sits atop the characteristic gold-colored oval base. An original production prop from *Star Trek: The Next Generation*—documented by Propstore and auctioned with a certificate of authenticity—served as the visual and dimensional reference. Propstore describes the prop as a silver-colored Starfleet delta on a gold-colored oval backing.
Original TNG reference:
https://propstoreauction.com/lot-details/index/catalog/319/lot/89871/Lot-1165-Star-Trek-The-Next-Generation-T-V-Series-1987-1994-Starfleet-Combadge
The Voyager version features a flatter gold-colored base shape with the Starfleet delta overlaid on top. An original production prop from *Star Trek: Voyager*—also documented by Propstore and offered with a certificate of authenticity—served as the reference. Additional reference material came from the personal collection of Michael and Denise Okuda, who played a pivotal role in the visual design of Star Trek productions. Original *Voyager* reference:
https://propstoreauction.com/lot-details/index/catalog/319/lot/89898
Additional *Voyager* reference from the Okuda collection:
https://www.icollector.com/1476-Michael-and-Denise-Okuda-Collection-Starfleet-Combadge-STAR-TREK-VOYAGER-1995-2001_i53492478
The models are designed for 3D printing; they can be printed in a single color and subsequently painted in the characteristic gold, silver, and dark gray tones. Multi-color printing has been prepared using the Anycubic Slicer. Depending on the printer and desired surface quality, a fine layer height is recommended to ensure contours and variations in depth are rendered cleanly.
This is an unofficial fan art project. *Star Trek*, Starfleet, the communicator badges, and all related names, designs, and trademarks are the property of their respective rights holders, specifically CBS Studios Inc. and Paramount. This model is not affiliated with, manufactured by, or endorsed by the rights holders. The linked production props and photographs serve solely as design and historical references; the images are not included with the model files. While the description utilized AI for referencing, the model itself did not.
If you like this, I can look for other documented combadges; leave a comment with your request, and I will try to create it promptly if possible.
Deutsch:
Star Trek Communicator Badges – The Next Generation und Voyager
Diese beiden Communicator Badges habe ich als eigene 3D-Modelle nach dem Erscheinungsbild der in Star Trek verwendeten Requisiten erstellt. Enthalten sind die klassische Ausführung aus Star Trek: The Next Generation sowie die spätere Variante, die unter anderem in Star Trek: Voyager verwendet wurde. Montiert wie im Orginal mit einem Klettstreifen, der hinten in eine Vertiefung eingeklebt wird.
Beim TNG-Communicator liegt das silberfarbene Starfleet-Delta auf dem charakteristischen goldfarbenen ovalen Grundkörper. Als visuelle und maßliche Referenz diente ein originales Produktionsrequisit aus Star Trek: The Next Generation, das von Propstore dokumentiert und mit Echtheitszertifikat versteigert wurde. Propstore beschreibt das Requisit als silberfarbenes Starfleet-Delta auf einem goldfarbenen ovalen Untergrund.
Originalvorlage TNG:
Die Voyager-Ausführung besitzt die flachere goldfarbene Grundform und das darüberliegende Starfleet-Delta. Als Referenz wurde ein originales Produktionsrequisit aus Star Trek: Voyager verwendet, das ebenfalls von Propstore dokumentiert und mit Echtheitszertifikat angeboten wurde. Eine weitere Referenz stammt aus der persönlichen Sammlung von Michael und Denise Okuda, die maßgeblich an der visuellen Gestaltung der Star-Trek-Produktionen beteiligt waren.
Originalvorlage Voyager:
Zusätzliche Voyager-Referenz aus der Okuda-Sammlung:
Die Modelle sind für den 3D-Druck vorgesehen und können einfarbig gedruckt und anschließend in den typischen Gold-, Silber- und Dunkelgrautönen bemalt werden. Mehrfarbdruck wurde vorbereitet mit dem Anycubic Slizer. Je nach Drucker und gewünschter Oberflächenqualität empfiehlt sich eine feine Schichthöhe, damit die Konturen und Höhenunterschiede sauber dargestellt werden.
Dies ist ein inoffizielles Fan-Art-Projekt. Star Trek, Starfleet, die Communicator Badges und alle zugehörigen Namen, Designs und Marken sind Eigentum ihrer jeweiligen Rechteinhaber, insbesondere CBS Studios Inc. und Paramount. Dieses Modell steht in keiner Verbindung zu den Rechteinhabern und wird von ihnen weder hergestellt noch unterstützt. Die verlinkten Produktionsrequisiten und Fotografien dienen ausschließlich als gestalterische und historische Referenz; die Bilder sind nicht Bestandteil der Modelldateien, die Beschreibung wurde durch eine KI referenziert, das Modell nicht.
Wenn euch das gefällt, suche ich noch andere belegte Combadges, hinterlasst einen Kommentar mit eurem Wunsch und ich probiere diesen wenn möglich Zeitnah zu erstellen.
Prop
Communicator
combadge
Star Trek
Enterprice
Voyager
TNG
