2026-09-24 00:04:36
889
41
Star Wars Droid Tri-Fighter 机器人三联战斗机
@YGG2Any_3251657
Affiliation:
Confederacy of Independent Systems
Manufacturer:
Colla Designs and Phlac-Arphocc Automata Industries
Size:
5.4 meters long
I really like its unique appearance
Model scale 1:24
Assembled model size approximately 221*140.5*121.5mm
  • The six wing panels use a 0.12mm layer height, making the curved surface layers look better.
  • A small hole is made on the upper wing, which can be used to hang the model with a string.
  • Some parts require glue, as marked in the Assembly diagram.
  • Due to differences in materials and machines, please test the installation of the front cannon before sliding it in. If there is considerable resistance, sand the wing first.
我很喜欢他独特的外形
模型比例1:24
拼装后成品约221*140.5*121.5mm
  • 六片机翼使用了0.12mm层高,弧面的层纹更好看一些
  • 上方机翼开了一个小孔,可用用线把模型挂起来
  • 部分位置需要用到胶水,图中有标记
  • 因为材料、机器的不同,前炮在滑入前,请先测试安装,如果阻力比较大,请先打磨下机翼。
Assembly diagram:
组装示意:
star wars
droid tri-fighter
spaces fighter
