2026-05-25 08:27:00
3.3k
51
Stealth Pop-Out Cupholder
@3DPrintOfficial_530346
STEALTH POP-OUT CUPHOLDER
3D Printable Kinematic Mechanisms Series
Published by 3D Print Official
Inspired by:
Grzegorz H. Baniak's patent
for confined space cup holders
—and the Saab 9-5 and Citroën C6 premium dashboard cupholders.
The Stealth Pop-Out Cupholder is a flush-mounting, mechanical storage solution designed for home usage, workspace desks, or any confined structural spaces where a minimalist profile is required. The design is inspired by the classic dashboard kinematics found in premium automotive interiors, specifically the Saab 9-5 and Citroën C6 mechanisms, as well as the geometric principles established in Grzegorz H. Baniak's patent for confined space cup holders. The entire mechanism has been completely re-engineered from the ground up to utilize an original, fully 3D-printable compliance architecture. A standard beverage can is securely supported by the deploying cantilever ring.
The entire mechanism consists of nine individually printed pieces and is engineered for zero-support printing to eliminate material waste. Countersunk screw channels are integrated into the housing for rigid attachment to desk edges, vertical panels, or custom enclosures.
For the build, the mechanical linkage components are designed to snap together smoothly using integrated friction-fit retention pins. The assembly can be done entirely by hand, as the design requires no secondary tools, hardware fasteners, or adhesives. Total assembly in under thirty seconds, with the full operational sequence demonstrated in the video above.
Share + Support
If you print this model, please:
  • Like the model, a simple Like helps a lot
  • Comment with photos of your print (I’d love to see different filament colors and light temperatures used!)
  • Share or repost to help other makers discover it, you can also
  • Donate coins on my official profile page via the Donation Button to enable improved future designs, and most importantly,
  • Subscribe by subscribing to my profile you get instant access to new designs. Happy Printing !
cupholder
cup
holder
cup holder
push-push
push
mechanism
mechanical
po-out
saab
9-5
citroen
c6
3dprintofficial
3d print official
support free
