2026-10-01 10:28:47
344
10
Stick of Dynamite | Realistic Prop
@IntroPrints_5942519
Want a realistic prop that looks just like a stick of Dynamite/TNT? This life-size model has realistic textures and even comes with an optional printed bundle so you can tie 3 sticks together into a bundle.
Assembly is just one step
  • Single stick
  • Simply take a fuse / wick and insert it into the tip of the dynamite, that's it!
  • Bundle of sticks
  • Place the triangular bundle on a flat surface, then place the 3 sticks inside the triangle. You can then slide the triangle up or down.
  • Then insert a fuse / wick into each of the 3 sticks as desired.
stick
dynamite
prop
cosplay
fake
no ace
bomb
