《解压蛋糕猫猫》是一款把美味生日蛋糕与萌系猫咪结合的多功能治愈小摆件。
萌猫从甜甜的蛋糕中探出头来,按压后不仅会回弹解压,还能触发 语音提示、可播放音乐、可更换自定义音效。内置 可充电电源,随时随地让可爱与治愈加倍.
既是桌面解压玩具,也是充满惊喜的小礼物(你也可以将想说的话放进去送给他/她)
Decompression Cake Cat "is a multifunctional healing ornament that combines delicious birthday cakes with cute cats.
The cute cat peeks out from the sweet cake, and when pressed, it not only bounces back to relieve stress, but also triggers voice prompts, can play music, and can change custom sound effects. Built in rechargeable power supply, doubling cuteness and healing anytime, anywher
Not only a desktop decompression toy, but also a small gift full of surprises
展示视频:把生日蛋糕做成解压猫猫?还能播放音乐?!太可爱了!
🔊 1. 新增语音与音乐模块(核心升级)
1. New Voice & Music Module (Core Upgrade)
按下猫猫头即可触发:
Press the kitty’s head to activate:
• 播放提示音
• Play notification sounds
• 播放音乐
• Play music
• 自定义音效(生日歌、提示音、搞怪音)
• Custom sounds (birthday song, alerts, funny effects)
更多互动乐趣,更有“惊喜感”。
More interactive fun with a delightful surprise.
🔋 2. 支持充电
2. Rechargeable Design
内置可充电电池。
Built-in rechargeable battery.
无需频繁更换电源,使用更方便。
No need for frequent battery replacement—much more convenient.
🎁 3. 绝佳礼物属性
3. Perfect Gift Choice
生日礼物首选(蛋糕 + 萌猫 + 自定义生日歌)。
Top pick for birthdays (cake + cute kitty + custom birthday song).
节日礼物 / 桌面摆件 / 解压玩具皆适用。
Great for holidays, desk décor, or stress-relief play.
可玩性高、治愈属性强。
Highly playful and wonderfully soothing.
🖨 4. 打印友好
4. 3D-Printer Friendly
单色打印结构清晰。
Clear structure optimized for single-color printing.
支撑少、难度低,新手友好
Minimal supports, easy to print, beginner-friendly.
------------------------------------------分割线----------------------------------------------
版本一:纯3D打印版
Version 1: Pure 3D Printed Version
这个版本猫猫中间设计了可以打印的弹簧装置,您仅用3D打印机就可以拥有一只解压可爱的猫猫,无需采购额外的配件。
This version of the cat features a printable spring device in the middle, allowing you to have a cute cat with just a 3D printer without the need to purchase additional accessories.
建议使用PETG或者PLA材料打印(弹簧需要用PETG材料打印,PLA打印的弹性没那么好),分体设计,可以无需多色打印
It is recommended to use PETG or PLA materials for printing (springs need to be printed with PETG materials, and the elasticity of PLA printing is not as good), with a split design that does not require multi-color printing
版本二:键盘轴版
Version 2: Keyboard Axis Version
当然我们还提供了可以装键盘轴的版本,装上机械键盘轴可以带来令人满意的手感和点击声
安装方式与纯3D打印版相同,将打印的弹簧机械键盘轴替代
Of course, we also offer a version that can be equipped with a keyboard shaft. Installing a mechanical keyboard shaft can bring a satisfactory feel and clicking sound
The installation method is the same as the pure 3D printing version, replacing the printed spring mechanical keyboard shaft
1.机械键盘轴体需要另外购买。亲测有声轴或静音轴的声音效果都不错(段落轴或线性轴也均可),我个人都很喜欢,请根据您个人喜好使用吧,喜欢清脆明亮声音的选择青轴一类的有声段落轴,喜欢声音沉稳一点的可以黑红轴类。tb或pdd找便宜的买就行了。
1. The mechanical keyboard shaft needs to be purchased separately. The sound effects of the audio axis or mute axis tested by myself are both good (paragraph axis or linear axis are also acceptable), and I personally like them. Please use them according to your personal preferences. If you like crisp and bright sound, choose audio paragraph axes such as the blue axis, and if you like a more stable sound, you can choose black and red axes. Just find a cheaper option for TB or PDD.
2.普通十字状的轴体和带有防尘边的轴体都可以顺利安装使用
(如果您安装键盘轴的时候过紧或者过松可以在切片软件中设置XY孔洞补偿以适配您的键盘轴)
2. Both regular cross shaped shafts and shafts with dust-proof edges can be installed and used smoothly
(If you install the keyboard shaft too tightly or too loosely, you can set XY hole compensation in the slicing software to adapt to your keyboard shaft)
版本三:音乐版
Version 3: Music Edition
内置语音/音乐模块,能触发 语音提示、可播放音乐、可更换自定义音效。内置 可充电电源,随时随地让可爱与治愈加
Built in voice/music module, capable of triggering voice prompts, playing music, and changing custom sound effects. Built in rechargeable power supply, allowing cuteness and healing anytime, anywhere
打印注意事项:
1.打印出来的猫猫头如果顶部有一圈一圈的层纹可适当降低层高打印
2.装配过紧或者过松可以通过调整设置里的XY孔洞补偿和外轮廓补偿,以达到最佳效果(材料类型,材料流量设置都会影响最终的打印尺寸,没办法一个图形适配全部材料和打印参数,这个得你们麻烦自己调整一下补偿参数)
3.打印小零件建议加裙边打印,并且在打印前清理打印板,或者打印板上涂胶后打印,接触面过小可能会导致打印失败
Printing precautions:
If there are layers of patterns on the top of the printed cat head, the layer height can be appropriately reduced for printing
2. If the assembly is too tight or too loose, you can adjust the XY hole compensation and outer contour compensation in the settings to achieve the best effect (the material type and material flow rate settings will affect the final printing size, and it is not possible to adapt all materials and printing parameters to one graphic, so please adjust the compensation parameters yourself)
3. It is recommended to add a skirt edge for printing small parts, and clean the printing board before printing, or apply glue on the printing board before printing. If the contact surface is too small, it may cause printing failure
