2026-03-30 04:17:28
7.2k
458
Sunflower Windmill - 608 Bearing Mod
@BamBamDesign_2075164
Sunflower Windmill - 608 Ball Bearing Mod (Official)
For 2 years, I have had the model "Sunflower Windmill" uploaded. It was showered with likes and won first place in the Floral Design Contest. Back then, I already provided a simple mod for 608 ball bearings for my Patreon members.
Now I have further optimized the design for 608 bearings—and not only that… an additional size has been added as well. The newly redesigned inlay covers also offer two advantages: 1.Single-color printing and 2. They cleverly conceal the bearing
Thanks to your amazing support, I now want to make this design accessible to everyone.
The Sunflower Windmill - Self adjusting Sunflower wind turbine
Spins in lowest breeze! Great spring & summer garden decoration
  • Super smooth spinning due 608 Ball Bearing (Skateboard Bearing)
  • Beautiful Windmill with a Sunflower Propeller Design
  • Self adjusting to wind direction through the Tail Blade
  • You can add 2 Propellers on one Axle with a distance
  • Choose your propeller sizes and directions (You get nice effects if you choose different directions)
  • Rods are stack able to your needed height
Printing:
Profile is tested with PETG HF & PLA 👍🏼 Prefer PETG for long life and warm enviroment!
Assembly:
You need 2x 608 Ball Bearing other parts are printed. Like this: https://amzn.to/4bRDDqr (Reflink)
Press Fit Connection.Not needed but you can use glue to combine forever.
Assembly Overview
Inlay Cover Assembly ( The optional cover is not needed) You can use it to print in single color and it protects the bearing.
Thanks to all followers and don't forget the virtual handshake 👍 ….Happy Printing
Check my other Windmill Designs: → Collection-←
Use this Clamp for Windmill, as well👍
Commercial license and more you find through my Linktree:
https://linktr.ee/bambamdesign
sunflower
windmill
turbine
wind
weather vane
sonnenblume
windrad
pinwheel
spinning
608 bearing
608 mod
ball bearing
spinner
flower
spring
186.60KB
