2024-11-21 19:06:40
5.2k
313
TEC 9 Historical Prop
@DrMussy_950260
我每周五上传一个新设计
Don't forget to "Click A Like" & check out my other Cool designs and Follow my Weekly dose of KooKoo uploads, PLZ leave a comment what you want next! Also dont forget to look at my other 800+ designs ;)
The Intratec TEC-9 was one of my favorite movie guns from the 1990's it was seen on Miami Vice as well as other TV shows and movies its a very iconic gun usually used by the bad guys, this little project brought back awesome childhood memories I hope you enjoy it as much as I have.
Prit Instructions
YES Supports Required, YES Brim or Raft required, Quick and easy print, very simple assembly!
BOM:
PLA Filament
2x M5 screws (upper and lower receivers)
2x Compression Spring 4.5 mm OD x 16mm L (trigger, magazine release)
2x 1.5mm pins x 36mm (trigger, magazine release)
12mm OD x 30mm L Compression Spring (bolt)
Superglue to join the upper components after inserting the bolt (Make sure you insert the bolt spring before you glue the parts together)
Print Settings:
0.2mm layer
6 Walls/Shells
20% Infill
Print Time:
less than 24hrs
Material Used:
Anycubic Silk PLA GRAY
Anycubic PLA+ BLACK
If you are interested in other prop firearms, Airsoft parts and designs do join our group on Matrix:
https://app.element.io/?pk_vid=f12152aac29bbc4a166549437941781a#/room/#GCI-General:matrix.org
!!!Note: I'm always open for suggestion and help on improving the design and proof of concept.
TEC9
MAC9
SMG
machine pistol
gun
