2025-12-10 06:02:21
452
14
THE GRINCH – Hueforge Painting no ace pro / ams
@GorilloneChaddo_1876803
🎄 THE GRINCH – Hueforge Filament Painting no ace pro / ams
This project, created with Hueforge, is a filament painting dedicated to everyone who hates Christmas… just like the Grinch. I wanted to create an elegant yet easy-to-print design, suitable even for those who don't have a multicolor system like AMS or ACE Pro.
No automatic color mixing is required: simply set manual pauses at the indicated layers, directly from the slicer.
⚙️ Recommended settings:
• Layer height: 0.08 mm
• Base layer: 0.16 mm
• Infill: 100% (Rectilinear)
• Wall loops: 1
• Model dimensions: 200 × 150 mm
• Maximum thickness allowed: 2.24 mm (effective 2.23267 mm)
• Brim: optional but recommended for improved adhesion
💡 It is possible to print with higher layers, as long as they remain below the base thickness of 0.48 mm.
🎨 PLA Used and Instruction for Swap/Pause:
• Start with Black
• At layer #7 (0.64mm) swap to White
• At layer #16 (1.36mm) swap to Black
• At layer #18 (1.52mm) swap to Red
• At layer #22 (1.84mm) swap to Yellow for the rest
🧩 An AMS/ACE Pro system is not required: simply insert manual pauses in the indicated layers.
🖨 Tested Printers
Anycubic Kobra 3 Combo 👉 Link
Anycubic Kobra 3 V2 Combo 👉 Link
🎁 Special Anycubic Discount
By purchasing through my affiliate link, you can use the following exclusive coupon code:
🧾 Coupon: WLOUTRVZCM
🎉 $20 OFF your order!
👉 Visit the Anycubic Shop
Kobra 3
Kobra 3 V2
Kobra 3 Combo
Kobra 3 V2 Combo
Ace Pro
No Ace Pro
Ams
No Ams
multicolor
filament painting
hueforge
Grinch
Christmas
new year
litophane
art panel
xmas
Decoration
home
gift
TXT
Grinch Settings.txt
534B
