2026-09-16 02:22:13
223
Table lamp "Neon Pulse
@Spokoyniy7_4227545
Title: Neon Pulse — Modular Cyberpunk PCB Table Lamp
Description:
Neon Pulse is a 3-part modular desk lamp inspired by integrated circuit boards and cyberpunk aesthetics. Internal illumination travels through trace-like channels along the outer shell, casting PCB light patterns across your workspace.
The lamp is engineered into 3 clean, easy-to-print parts:
  1. Main Body: The central vertical tower featuring intricate circuit channels and a top ambient light aperture.
  2. Base Platform: Stable lower mount housing the wiring routing and power inlet (USB-C / Switch).
  3. Bottom Cover: A flush bottom plate that securely seals the base from below, concealing all cables and electronics for a finished look.
🛠 Hardware Requirements
  • Lighting: 5V Addressable RGB LED strip (WS2812B / SK6812) or high-density COB LED strip.
  • Power: USB-C breakout module or direct cable pass-through.
  • Control (Optional): Compact WLED controller (ESP32/ESP8266), SP107E, or inline power switch.
  • Hardware: M3 heat-set inserts + M3 screws (or secure press-fit).
