2026-07-29 16:00:25
384
9
Tactical Utility Knife
@MoGoARt_4815258
NOTE
My models don't bite... but they might have the occasional bug! If you find something weird, please let me know instead of feeding the comment section to the angry gremlins. Constructive feedback helps me squash bugs, improve the models, and make them better for everyone. Thanks for being awesome and helping out! ❤️🧸
Tactical Utility Knife – Lightweight EDC with Lattice Handle
A compact, lightweight tactical utility knife designed for everyday carry (EDC), workshop use, and outdoor tasks. The ergonomic finger-ring design provides a secure grip and excellent control, while the lightweight lattice structure keeps the handle strong without unnecessary weight.
The handle is designed to accept a standard utility blade, making blade replacements quick and inexpensive. It also includes a paracord/lanyard attachment for easy carry and retrieval.
  • 🔹 Compact and lightweight EDC design
  • 🔹 Secure finger-ring grip for improved control
  • 🔹 Strong lattice construction
  • 🔹 Comfortable ergonomic handle
  • 🔹 Standard utility blade compatible
  • 🔹 Quick blade replacement
  • 🔹 Lanyard attachment
  • 🔹 Perfect for camping, workshops, makers, and everyday utility
Printing
This model has been designed to print successfully with any infill pattern.
Recommended settings:
  • Layer Height: 0.20 mm
  • Walls: 3–4
  • Top/Bottom Layers: 4–5
  • Infill: 15–30% (any pattern)
  • Supports: Not required
  • Brim: Optional
PLA works great, while PETG or ABS provides increased durability.
Assembly
  • Install a standard utility blade.
  • Secure the blade using the included fasteners.
  • Attach your preferred lanyard or paracord if desired.
Notes
  • Designed for strength while minimizing material usage.
  • The lattice structure maintains rigidity while reducing weight.
  • Compatible with common utility blades available worldwide.
Safety
⚠️ This model uses a sharp utility blade.
  • Handle with care.
  • Keep away from children.
  • Always retract or cover the blade when not in use.
  • Wear appropriate protective equipment during assembly and use.
knife
utility knife
tactical knife
box oppener
box cutter
camping
hiking
hike
outdoors
indoors
office
home
work
dayliuse
blade
hand tools
fidgget
