2026-03-11 23:25:15
1k
74
Tea Light Easter Egg
@Kubino4_5594794
Brighten your home this Spring with the Floral Easter Egg!
This elegant, one-piece print features an intricate daisy pattern designed to cast beautiful floral shadows. It’s the perfect centerpiece for your Easter table or a cozy night light.
Specifically designed to be used with LED tea lights for a safe and magical glow. For the best fit and effect, I recommend using these:
🔗 Recommended LED candles: Bambu Lab LED Tea Light Set
Features:
  • One-Piece Design: Print it in one go—no assembly needed.
  • Intricate Shadow Play: The petal cutouts create a stunning light effect on nearby surfaces.
  • Modern Aesthetic: Looks like premium ceramic when printed in matte or marble finishes.
Anycubic Print Settings (AnycubicSlicer / Cura):
  • Printer: Optimized for Anycubic Kobra 2/3 series and Photon (FDM).
  • Filament: Recommended Anycubic High Speed PLA or Anycubic Silk PLA (White/Marble).
  • Layer Height: 0.24 mm (Perfect balance between speed and detail).
  • Supports: Enable Tree Supports (or Organic supports).
  • Post-Processing: Internal supports can be easily popped out through the bottom using a flathead screwdriver.
  • Infill: 10-15%.
⚠️ SAFETY FIRST: Use LED lights ONLY. Do not use real wax candles, as the heat will melt the plastic (PLA).
Show off your print!
If you enjoy this design, please leave a Like and upload a photo of your make! I’d love to see how it looks on your Anycubic printer.
easter
egg
easteregg
spring
homedecor
decor
decoration
latern
floral
led
