2026-10-17 11:08:05
1.3k
154
The High Voyager 2 – Alien Backflow Incense Burner
@poneko_1917645
🛸 The High Voyager 2 — Smoke From the Mouth!
The incense hides inside the UFO. The smoke comes out of the alien’s mouth.
Meet The High Voyager 2: a relaxed alien sitting cross-legged on a flying saucer, holding a tiny cigarette while real incense smoke escapes through its mouth. A hidden chamber and internal smoke channel bring the scene to life.
🚀 How It Works
The model has three main parts:
  • Alien & UFO Top: The removable upper section includes the alien and an internal channel that guides smoke toward its mouth.
  • UFO Base: The hollow saucer houses the incense setup and provides access for cleaning.
  • Incense Support: A separate piece positions the incense inside the chamber.
The cigarette is part of the sculpture. The burning incense goes inside the saucer, not in the alien’s hand.
🔥 Incense & Assembly
This model is intended for backflow incense, positioned inside the UFO as shown in the setup photos.
  1. Remove the upper section to access the chamber.
  2. Position the separate incense support inside the base.
  3. Fit the protective metal insert or foil barrier and check that the incense is stable and that no burning material or hot ash can contact the plastic.
  4. Follow the incense manufacturer’s lighting instructions, then carefully refit the upper section without disturbing the incense.
The smoke travels through the internal channel and exits through the alien’s mouth.
Check the setup photos before use. Incense dimensions and shapes vary; make sure yours fits with adequate clearance from the printed parts.
🌬️ Those Holes Are Intentional!
The openings underneath the UFO provide ventilation for the incense chamber. Keep them unobstructed during use.
🖨️ Printing & Assembly Notes
  • Recommended material: PETG rather than standard PLA, for its higher heat resistance.
  • Assembly: Position the separate incense support inside the lower base, then fit the alien/top section onto the saucer.
  • Before use: Check that the ventilation openings and smoke channel are clear.
PETG is not fireproof. Printed parts can still deform or ignite if exposed to excessive heat.
⚠️ Read Before Burning Incense
This design combines burning incense with printed plastic components and requires careful setup and supervision.
  • Never leave burning incense unattended.
  • Keep the burning incense, hot ash and heated components from contacting the plastic.
  • Use a stable, nonflammable, heat-resistant surface.
  • Metal or foil is an additional precaution—not a guarantee of fire safety.
  • Keep ventilation openings clear.
  • Let everything cool completely before handling, opening or cleaning.
If you cannot safely isolate the burning incense and hot ash from the plastic, use the model as a decorative piece only.
Whether displayed on its own or used with a suitable incense setup, this little traveler brings a relaxed sci-fi mood to your space. 👽
alien
incense holder
alien incense holder
decorative
incense burner
burner
zen
space
UFO
aliens
smoking
backflow
backflow incense
