2026-10-24 03:49:59
70
The PryClever 🛠️🚀
@3DByRyan_1015564
Meet The PryClever—the ultimate pocket companion designed to handle the heavy lifting without scratching your surfaces! Engineered for maximum leverage and durability, this handy EDC pry tool tackles tight gaps, stubborn clips, and daily opening tasks with ease.
💪 Sinfully Strong: Optimized geometry provides incredible stiffness and strength where you need it most.
🖨️ Easy Print: 100% print-in-place with zero supports required. Just slice, print, and put it to work!
🎒 Everyday Utility: Lightweight and compact enough to fit on your keychain or slide right into your pocket.
Upgrade your toolkit in under an hour! 🛠️⚡
pry
tool
bar
strong
handy
cheap
compact
scalable
