2026-01-13 00:46:10
894
14
The Starry Night in Kumiko (traditional Japanese Style)
@DaRuizer_3174750
ENGLISH
Van Gogh's Starry Night in Kumiko Style (traditional Japanese art)
Attention: This project is very long. It measures 1200x670mm. It is optimized for the build plate of a Kobra 3 or a printer of the same dimensions. You can increase the number of pieces printed per bed to reduce the number of prints if your bed is larger.
I hope you enjoy the process as much as I did. The entire assembly process is very relaxing and fun.
Assembly instructions are included and written with minimal words but accompanied by numerous images to be understandable for everyone, even those who don't speak the language. Please pay attention to these.
If you have any questions, leave a comment and I will answer as soon as possible.
IMPORTANT: DO NOT SCALE THE PROJECT. YOU WILL HAVE MANY PROBLEMS.
It is designed for these dimensions and optimized for minimal filament consumption. During assembly or transport, you might break a small piece that covers the seams between panels, as they only have one wall. If this happens, don't reprint it; you can easily replace it with super glue.
The most distinctive feature of Japanese Kumiko art is how its pieces fit together like a puzzle. This project has those same characteristics. You will only need a small amount of super glue to join the panel lines in the center—literally 15 drops.
It consists of two phases. Please pay attention to the number of times each layer needs to be printed. Sometimes only one print is required, and other times the same layer may need to be printed 12 times. This is all indicated in the names of each layer.
The first phase is the project that includes the Kumiko frame. Please don't despair; once everything is printed, you will see that assembly is much simpler than it seems. Just make sure everything is clearly marked until you begin assembly. Many pieces from different beds look the same. THEY ARE NOT. A few millimeters can complicate the assembly. By simply following the images in the glossary at the end of the instructions, you will be able to complete it. Start in reverse, like a puzzle, joining all the panels and then the frame. I made one for my 13-year-old nephew, and he assembled it in 3 hours without asking me a single question.
The second phase is the insert project. Please feel free to modify them to your liking. But in return, I hope you will send me photos of the result.
Thank you very much, and enjoy the process.
ESPAÑOL
La Noche estrellada de Van Gogh en estilo Kumiko (arte tradicional japones)
Atencion, Este proyecto es muy largo. Mide 1200x670mm. Esta optimizado para realizarse en la cama de una Kobra 3 o impresora de mismas medidas. Usted podra aumentar el numero de piezas que se imprime en cada cama para reducir el numero de impresiones si su cama es de mayor tamaño.
Ojala disfruten tanto como yo durante su proceso. Es muy pero que muy relajante y divertido todo el proceso de montaje.
Las instrucciones de montaje estan incluidas y redactadas con el minimo de palabras pero acompañadas de numerosas imagenes para ser comprensibles para todo el mundo que no entienda el idioma. Por favor, preste atencion a estas.
Si tiene cualquier duda. Deje un comentario y le respondere en cuanto pueda.
IMPORTANTE. NO ESCALE EL PROYECTO. TENDRA MUCHOS PROBLEMAS.
Esta diseñado para estas medidas y optimizado para el minimo gasto de filamento. En el montaje o traslado puede que se le rompa alguna pequeña pieza de las que tapan las juntas entre paneles, ya que solo poseen 1 pared, en tal caso, no vuelva a imprimirla, puede colocarla perfectamente con pegamento rapido.
Lo mas distinguible del arte Kumiko Japones, es como encajan sus piezas a presion como si de un puzle se tratara, Este proyecto contiene esas mismas caracteristicas. Solo necesitara una pequeña cantidad de super pregamento para la union de las lineas de paneles en el centro, literalmente son 15 gotas de pegamento las que se necesitan.
Consta de 2 fases, por favor, preste atencion al numero de veces que hay que imprimir cada cama, algunas veces tan solo se neceta 1 impresion y otras pueden ser 12 veces la misma cama, todo ello esta indicado el los nombres de cada cama.
La primera fase es proyecto que incluye el marco Kumiko. Por favor, no despere, cuando tenga todo impreso vera que montarlo es mucho mas sencillo de lo que parece. Tan solo tega todo bien marcado hasta que comience el montaje. Muchas piezas de distintas camas parecen iguales. NO LO SON. unos simples mm pueden complicarle el montaje. Unicamente guiandose por las imagenes del glosario al final de las instrucciones, será capaz de realizarlo. Comience al revés que un puzle, uniendo todos los paneles y despues el marco. Hice uno para mi sobrino de 13 años y lo monto en 3 horas sin preguntarme absolutamente nada.
La segunda fase es el proyecto de los insertos. Por favor. Sientase libre de modificarlos a su gusto. Pero a cambio espero que me envie fotos del resultado.
Muchas gracias y disfruten del proceso.
Art
Decor
Kumiko
Japan
Japanese
Style
patreon
Van Gogh
Starry Night
Artist
big
home
exclusive
modern
3d
traditional
terapy
fashion
PDF
PDF instrucciones .pdf
1.06MB
PDF
Desglose piezas pratrones.pdf
280.12KB
