2024-12-01 07:14:35
1.3k
54
Torre Pot, Stackable planter
@moixo_4238103
I hope that this stackable desing helps you to put a bit of green on your life
PETG recommended
  • Tested with 3 floors, but although it can handle more then you will need to check how you are going to irrigate the lower floors.
  • The base is not mandatory, specially in the outside.
  • Two files. The first is for the pot floor, the second is the base. Print as many floors as you want.
  • Feel free to scale if you need it, but remember to put the same value in the two files.
Print Instrucctions
  • 0.2 layer height, but you can also use a higher value
  • 3 walls arachne
  • 0.2 infill gyroid or cubic
  • 1mm bottom and top
planter
Stackable
pot
maceta
