2024-06-15 11:00:14
2.6k
141
Travel Ukulele
@ProjectPioneer_5944722
An attempt to create a travel ukuleleI tried to make it as simple as possible using glue and only 1 screw.
The tuners I bought on Aliexpress link below:https://pt.aliexpress.com/item/1005001570809164.html
The screw I used was an M5x80mm with a nut to hold the pulleys.
My printer is 225x225mm and I was able to print on the edge of the bed. So I believe that any printer of that size will also be able to print.
Important!Due to the high tension of the strings it is important to print the neck and body with a high infill and at least 6 walls (if you can put 8), otherwise the pressure will warp the ukulele
In the region of the tuners I recommend doing a 100% filling using a modifier in the slicer, I attached an image of PrusaSlicer as an example.
music
guitar
ukulele
travel
string
hawaii
