2026-08-04 20:29:53
3.6k
290
Turbo Spool Winder with bearings
@AndyCar_2688600
While looking for a filament winder, I found an excellent one, this one from "@DaveBeau".
But verything can be improved, so I made a few changes.
  • The base was a two-piece design; now it's a single, reinforced piece, and the print no longer fails. (No more joints and glue.)
  • It used to require six 6901 bearings and two 6802 bearings; now it works with eight 6802 bearings. (Fewer parts to buy and easier assembly, although this meant modifying all the axes.)
  • Added two feet for greater stability.
  • Added shims to center the receiving spool.
  • Added a wrench to remove the spool adapters.
Don't forget to PAUSE he process to insert the bearings onto the axles. 15mm bearings, type 6802 (15*24*5)
- Worm shaft stop at level 127
- Receiving shaft stop at level 92
- Donor shaft stop at level 66
You will need five more 6802 bearings:
- 2 for the idler gear
- 1 to be inserted directly into the winder body for the tip of the worm shaft.
- 2 to be inserted into the winder body for both the receiving shaft and the donor shaft tips.
Assembly video here:
You can see it in action here.
bearings
ballbearings
winder
spool
spool winder
spooler
respool filament
respooler
filament
filament accesory
rewind
