2026-04-21 04:42:18
530
Two-Hook Feeder Rig – Safer & More Effective Fishing
@User_826224
Fish smarter with this dual-hook feeder system. Test two baits at once, reduce tangles, and improve safety if breakage occurs.
Why Two Hooks?
Using two hooks on a feeder rig isn't just about catching more fish – it's about testing and efficiency:
  • Try two different baits under identical conditions to see what the fish prefer.
  • If one bait fails, the second hook gives you a backup chance.
  • Great for competitive fishing or simply learning what works best on the day.
The Problem with Other Rigs
Most dual-hook solutions have serious flaws:
  • Tangling – Hooks and lines twist into an unusable mess during casting.
  • Stiff tubing – Rubber separators are rigid and spook wary fish.
  • Safety risk – If the rig breaks, a fish can swim away trailing a hook, line, and feeder – often fatal.
How This Rig Solves the Issues
Tangling -Tube separators keep lines apart during casting
Stiffness - Lightweight, flexible design is less detectableBreakage -Weakest point is the hooklength (8cm), not the main rig – if it snaps, the fish escapes cleanly
⚠️ Important Note
This rig is not perfect. In rare cases, a hooklength can still wrap around the separator during casting. If the main line breaks, the rig may not fully separate. I welcome your feedback and improvements – let's make it better together.
✅ Always check local regulations – some waters restrict two-hook rigs.
🖨️ Print Settings
  • Material: PETG or ASA (not PLA – needs flexibility)
  • Walls: 2 perimeters (no infill needed)
  • Supports/Brim: Not required
  • Print-in-place: Ready to use after printing
📢 Ready to Test?
👉 DOWNLOAD and try two baits at once
👉 SHARE YOUR RESULTS – tag your catches and feedback
👉 REQUEST CUSTOM SIZES – message me for modifications or new ideas
fishing
feeder
development
two hooks
