2026-10-06 14:06:40
1.2k
34
UFO Flying Saucer desk lamp accent light
@BC3D_1656011
NOTE: See additional print quality updates in the comments section below.
-My original design, 100% hand measured, made from scratch in TinkerCAD
-Actual print photos shown, No AI was used.
-Entry for Anycubic Space Exploration Design Contest
VIDEO https://youtube.com/shorts/rrHA0LnDjpw
PRINTING
  • -3 separate print profiles 1) the upper and lower discs 2) the stand and lower mount (transparent) 3) the inner puck sleeve
  • -Discs default to .20 layer 8% gyroid infill, 25mm/sec outer wall, 100mm/sec inner/top layer speed, 220noz temp & 100% fan all layers, 7 walls, 8% infill/wall overlap, .5mm outer wall, .5mm inner wall.
  • -Adjust your nozzle temperature settings according to your filament manufacturer recommended settings. This model defaults the discs to 220 nozzle temp.
  • -Supports are pre-set per plate/model, no need to modify
  • -I'm using Random Seam, feel free to use aligned seam
  • -Simple design, 5 parts, designed for easy disassembly to recharge puck lights.
  • -DO NOT USE GLUE, bottom stand threads into lower mount of UFO
  • -Assembled dimensions: Base width 108mm, Saucer width 200mm, overall height approx 222mm
  • -Currently Testing - Scarf joint seam, PLA Silk, other quality settings
Use Transparent PETG/PLA
  • -Ray beam (stand)
  • -Main base
Use Grey/Silver PETG/PLA
  • -Top disc
  • -Bottom disc
  • -Puck light sleeve
Use these PUCK LIGHTS (USB-C rechargeable & remote controlled)
Amazon Affiliate Link: https://link.amazon/B05CNFGdb
3.15"L x 3.15"W x 0.59"H
ASSEMBLY
NEW: Moon base slab (separate download)
https://www.makeronline.com/en/model/Moon%20surface%20base%20slab%20for%20UFO%20desk%20lamp%20accent%20light/339463.html?trackModuleType=10
Eryone Silk Silver PLA shown below (random seam)
https://link.amazon/B0hLdxM5r
Anycubic PETG Below (scarf seam)
https://link.amazon/B0gJstXjf
Thank you for your interest and support!
Use COUPON CODE "BC3D" for $15 OFF Anycubic products
https://store.anycubic.com/?ref=BC3D
ufo lamp
ufo desk light
ufo accent light
ufo accent lamp
puck light lamp
puck light desk lamp
flying saucer lamp
flying saucer light
area 51 lamp
area 51 light
alien spaceship
alien spacecraft
alien ufo
uap desk light
uap desk lamp
uap accent light
uap flying saucer
uap ailen ship
ufo alien ship
