2026-09-15 02:39:54
2k
262
Ultimate Modular Spray Can & Silicone Tube Organizer Rack
@LukiLan_2344673
Keep your workshop, garage, or craft room perfectly organized with this fully modular and expandable storage system!
If you are tired of knocked-over spray paints and messy silicone tubes rolling around your shelves, this 3D-printable rack is the perfect solution. Designed with flexibility in mind, this system allows you to build a custom storage rack tailored exactly to your space and needs.
🌟 Key Features:
  • Fully Modular & Expandable: Build it as wide or as tall as you want! The modules can be infinitely duplicated and connected together.
  • Two Plate Sizes Included:
  • Large Format Plate (4 Slots): Perfectly sized for standard spray paint cans.
  • Small Format Plate (8 Slots): Perfectly sized for silicone tubes, glues, and smaller aerosols.
  • Sturdy Assembly System: The plates are joined together securely using custom-designed locking pins and structural front/back support beams, making the entire rack highly stable even when fully loaded.
  • Space-Saving: Maximize your cabinet or shelf space by stacking your supplies neatly.
🛠️ Assembly:
Assembly is straightforward and requires no glue or extra hardware.
  1. Choose the plates you want to use (4-slot for sprays, 8-slot for silicones).
  2. Connect the base plates together using the provided interlocking pins.
  3. Slide the support beams into the designated slots on the front and back to provide structural rigidity.
  4. Stack the next layer of plates on top and repeat!
🖨️ Print Settings & Recommendations:
  • Material: PLA
  • Tip: You may want to use a brim for the small locking pins depending on your printer's bed adhesion.
Check out the uploaded photos to see the assembly process and how great it looks when fully loaded in a cabinet!
(Let me know if you need any specific dimensions added to the description, or if you want to tweak any details!)
