2026-05-18 17:49:44
5.7k
730
Under-Cabinet Paper Towel Holder - Honeycomb Kitchen Organizer - Useful Kitchen Accessory
@octAC_2475916
Clear off your kitchen countertops and reclaim your workspace with this ultra-modern, space-saving Honeycomb Paper Towel Holder! Meticulously engineered to blend structural strength with a sleek, minimalist aesthetic, this under-cabinet mount keeps your kitchen roll easily accessible while completely hiding it under your cupboards for a beautifully organized look.
Features:
  • Sleek Honeycomb Matrix: Designed with an elegant, high-tech hexagon mesh pattern that reduces print time and material usage while maximizing structural rigidity.
  • Smart Modular System: Features fully 3D-printable large threaded locking knobs that keep the roll securely in place and make changing rolls quick and satisfying.
  • Premium Countertop Saver: Mounts cleanly under any cabinet, cupboard, or workshop shelf, turning wasted vertical space into practical utility storage.
  • Customizable Installation: Designed with a smooth top surface for clean adhesive tape mounting, or you can easily add custom screw holes in your favorite slicer for a permanent, heavy-duty mount.
Supports: NO supports required.
Assembly: To assemble a complete holder, you will need to print 2x Brackets and 2x Screws (Knobs).
Warnings: To ensure the threads work perfectly, please make sure your printer's flow and e-steps are well-calibrated.
Tolerance Tip: If the 3D-printed threads fit too tightly due to your printer's tolerances, simply re-scale the Screw (Knob) down by -1% only along the X and Y axes in your slicer for a perfectly smooth, buttery fit.
paper towel holder
kitchen organizer
under cabinet mount
space saver
honeycomb design
kitchen roll dispens
functional print
modular assembly
organization gear
clever utility
household hacks
util
kitchen decor
home decor
