2024-04-25 02:06:09
5.8k
511
Undertale Keychain and Wall Art Pack - Sans, Annoying Dog, Flowey, Temmie, and Frisk
@Powerpillprints_2496744
This pack has been all set up for super simple and easy printing with the AMS or AMS lite!
All the models are set to 2 or 4 Colours! Just load your filament, slice and go!
This pack includes the following Characters: Sans, Annoying Dog, Flowey, Temmie, and Frisk keychians with Sans and Papyrus Wall art!
I have this set to use the 0.4mm nozzle with a .28mm layer height. This prints three layers of colour so the colours turn out nice and saturated and minimize waste. After the colour, there's one solid black layer, three layers of infill, and four final solid layers for the back for strength with the back pattern set to Hilbert Curve for a nice texture. There is a small hole in each model which is just large enough to fit a 1mm keychain jump ring. If you find it too small, you can modify the size of the “Keyhole” object in BambuStudio to make it a little larger, or take a small drill bit and drill the final keychain to make it a little bigger!
I purchased my keychain set from Amazon if you'd like to get something similar!
Want to remove the keyhole? No problem! Each keychain has a “Keyhole” object on each plate. Just select it, delete it, and re-slice!
Want to make the wall art larger? Scale it up to fit your print bed! Both wall art plates have been sized to the A1 Mini Print bed, but can be easily scaled to fit larger print beds.
If you notice any settings that could be changed or improved, please let me know! I'd love to make any adjustments necessary so they all print great!
undertale
deltarune
indie game
nintendo
nintendo switch
video game
gaming
gamer
retro
PC
keychain
sans
flowey
temmie
frisk
papyrus
gaster
napstablook
toby fox
game art
