2026-08-08 01:11:50
514
14
Universal Tube Squeezer | Toothpaste & Cream Roller
@CornerStone3D_1052388
Stop fighting with half-empty tubes.
This Universal Tube Squeezer is designed to help push out more of the product trapped inside toothpaste, creams, gels, ointments, cosmetics, and other flexible tubes.
Simply feed the end of the tube through the center slot and rotate the base to gradually roll and squeeze the contents toward the opening.
The tall body helps keep the tube contained as it rolls, while the wide base makes it easy to grip and turn.
Dimensions
  • Height: 117 mm
  • Circumference: 60.5 mm
Printing
All included files are provided in 3MF format.
Supports are required for the base only.
The rest of the model is designed to print without supports.
Depending on your printer and slicer settings, minor adjustments may be needed.
Great For
  • Toothpaste tubes
  • Hand cream
  • Lotion
  • Cosmetic tubes
  • Ointment
  • Gel
  • Adhesive tubes
  • Paint tubes
  • Kitchen pastes
  • Other flexible squeeze tubes
A simple reusable tool for getting more out of every tube and reducing waste.
tube squeezer
toothpaste squeezer
toothpaste roller
tube roller
cream squeezer
lotion squeezer
toothpaste dispenser
tube dispenser
bathroom organizer
bathroom accessory
kitchen gadget
cosmetic organizer
waste reducer
houshold tool
universal tube squee
