2026-09-29 03:25:49
846
53
Vertical Scale Stand
@Tomasz_1742866
⚖️ Vertical Scale Stand
✨ Minimalist Space-Saving Holder
Sometimes the best solutions are the simplest ones.
The Vertical Scale Stand was designed with one clear purpose — to store your scale vertically while taking up as little space as possible.
Instead of leaving your scale flat on the floor or occupying valuable shelf space, simply slide it into the holder. The scale stays stable, accessible and neatly organized, while the stand keeps your space clean and uncluttered.
✨ Designed Around Simplicity
The design intentionally avoids unnecessary elements.
Clean geometry, compact dimensions and a minimalist form make the holder a natural fit for modern interiors, while its practical construction keeps everyday storage simple and convenient.
It is more than just a holder — it is a small piece of functional design created to make better use of your space.
⭐ Key Features
🔹 VERTICAL STORAGE
Keep your scale upright instead of taking up valuable horizontal space.
🔹 SPACE-SAVING DESIGN
A compact footprint helps keep floors, shelves and workspaces organized.
🔹 STABLE SUPPORT
Designed to hold the scale securely in an upright position.
🔹 MINIMALIST AESTHETICS
Clean lines and simple geometry create a modern, unobtrusive look.
🔹 FDM FRIENDLY
Designed specifically with easy FDM 3D printing in mind.
🔹 NO SUPPORTS REQUIRED
Print the model without complicated support structures.
🔹 PLA & PETG COMPATIBLE
Choose the material that best suits your application.
🖨️ 3D Printing
The model is designed for standard FDM 3D printers and requires no complicated assembly or additional components.
📌 Recommended nozzle: 0.4 mm
📌 Recommended layer height: 0.20 mm
📌 Supports: Not required
📌 Materials: PLA / PETG
Dedicated print profiles for PLA and PETG are included for a straightforward printing experience.
🏠 Made for Everyday Life
A small, simple object can make a surprisingly big difference.
Less clutter. Less wasted space. More organization.
Minimal form. Maximum use of space.
ScaleHolder
ScaleStand
VerticalStorage
SpaceSaving
Storage
Organizer
HomeOrganization
MinimalistDesign
Home
Household
Utility
FunctionalDesign
ModernDesign
SpaceSaver
