2025-09-23 15:27:53
2.9k
287
Voron Cube Test - Kobra S1
@Flavia_1779827
This 30 mm test cube is designed for calibrating and fine-tuning the Anycubic Kobra S1 Combo. It helps you quickly verify the accuracy of your printer after setup, upgrades, or adjustments.
What you can test:
  • Dimensional accuracy (X/Y/Z = 30 mm target)
  • Flow calibration (under-/over-extrusion)
  • Layer consistency and alignment
  • Vibrations, ringing/ghosting on sharp edges
Tips:
  • Print with your standard profile (no scaling).
  • Measure all three axes with calipers and compare to 30 mm.
  • Use results to fine-tune e-steps, flow, or belt tension.
A simple, reliable way to keep your Cobra S1 Combo perfectly dialed in.
voron
cube
cubo
test
teste
S1C
kobra
s1
combo
