2026-09-23 05:26:49
244
Wall Mounted Flower Planter Set – 6 Sizes
@alexs1499_2328520
A modern and practical set of wall-mounted flower planters, designed to bring style and greenery to any indoor or outdoor space.
This collection includes 6 different sizes in total: 3 standard versions and 3 side-connectable versions.
The side-connectable models include a side connection hole, allowing multiple planters to be joined together laterally for a cleaner and more modular wall setup (the connection does not support without the top screw!).
The planters feature a clean geometric shape with an elegant ribbed front texture, giving them a modern decorative look while remaining functional and easy to print.
Perfect for flowers, herbs, succulents, and small plants, these planters are ideal for walls, fences, balconies, patios, terraces, and indoor green corners.
you have holes on the bottom so you can stack one onm top of eachother and water from the top
  • 6 sizes included
  • 3 standard versions
  • 3 side-connectable versions
  • Side hole for joining planters laterally
  • Wall-mounted design
  • Modern ribbed front texture
  • Clean decorative shape
  • Great for vertical garden setups
  • Suitable for indoor and outdoor use
  • Ideal for flowers, herbs, succulents, and small plants
Printing Info
  • Easy to print
  • No supports recommended in most cases
  • Recommended materials: PETG, ASA, ABS, or PLA+
  • PETG or ASA recommended for outdoor use
  • Print different sizes to create your own custom wall layout
PLANTER
plant
plants
roses
garden
outdoor
diy
cool
